android 4.3 bugs with nexus 4
Maybe I should open a post about all the good things about 4.3. I could call it 4.3 running well? Post here with positive feedback only.
Sent from my GT-I5800 using AC Forums mobile app
4.3 has been out for awhile, I think most the bugs gave been ironed out already, 3rd party apps updated really solved most issues.
Holding off on this update, saw it come into my phone and after reading this will stick with what I got.
I'm still not experiencing any issues. My battery has been off the charger since 8am and I still have 50% battery life with heavy usage(3 hours spotify, lots of text, an hour of phone calls) and more beyond that including web browsing. I do believe some people have issues, but they are easier to spot when you are looking for them. I've found 4.3 to continue to be fast and stable
Yes, I have experienced the same bug with android 4.3. I can't find a repetitive scenario when it shuts off by itself. Actually the phenomenon is that the phone goes into a mode where the screen is shut down, calls are automatically rejected as though the phone is off but, strange enough, the led at the bottom of the device is blinking at very low rate.
Unfortunately I experienced the same annoying behavior without any circumstantial connection I could point to. But then I installed version 4.4 and guess what? The problem got MUCH WORSE!
It shuts down by itself several times a day effectively making the device unsuable. LG/Google WAKE UP before the problem is spread across the net.
Andy
agahsha8
