Android 6.0 Marshmallow for the Moto X Pure Edition (24.11.18)
Re: Downloading OTA right now. ..
Also, I think most people will be happy with Marshmallow. Trying to be careful here, but I have been on it for several weeks.
Some comments:
(1) I am not sure about Adoptable Storage on the SD card, but that is a personal preference.
(2) While the sound and notification scheme is not as bad as Lollipop, I would still rather see the Gingerbread scheme of being able to separate notifications from the ringer without having to go to an app.
(3) My battery life seemed to improve a little, and my phone seems to run cooler on 6.0.
Posted from my XT1575
Re: Android 6.0 Marshmallow for the Moto X Pure Edition
Installing the update now!
I took my sim card out and it let me download. have not installed yet tho
Nothing major, just slight hesitations here and there that my Turbo never had. I probably made it sound worse than it actually is. I'm downloading the OTA right now, we'll see how she runs soon. Check for update folks!
I'm actually having the opposite experience, less lag on MXP than my Turbo. Particularly in the Zooper widget and in Settings. For some reason my Turbo would always freeze when I placed a Zooper on my screen and then opened the files to choose one. I would have to wait before I could scroll through them. Very frustrating, but I lived with it. Same thing with "Settings" and then "Apps." Always froze for a minute before I could scroll through Apps under Settings. Overall experience so far is better on the MXP for me.
I'm diggin' the new boot theme...nice!
Story is on the main AC page. Full rollout to MXPE on Verizon, Sprint, and U.S. Cellular. No idea why AT&T and/or T-Mobile are delayed.
T-Mobile may be because they haven't finished certifying the Pure for Band 12 use yet. I've seen mentioned a few times that it is a rather long and expensive process to get non T-Mobile phone certified for band 12. No idea on AT&T unless there is some bug related to the radios but I have been rocking MM on my AT&T pure for well over a month now and have had zero issues.
I had those pop up from time to time on 5.1.1 and 6.0 got rid of every bit of it. Have had zero stutter or lag of any kind on MM.
Awesome, great to hear! I'm playing with it right now and so far seems super smooth.
Marshmallow being pushed OTA now
Getting my update on my moto x pure edition on Verizon. Check your phone for an update.
For AT&T & T-Mobile user wanting Mashmallow
Turn off your phone, take out your SIM, and turn your phone back on. You should then be able to get the update when you check for it in settings.
Re: Marshmallow being pushed OTA now
For AT&T & T-Mobile users: Turn off your phone, take out your SIM, and turn your phone back on. You should then be able to get the update when you check for it in settings.
Got mine on Verizon 😁 its nice.
Quick question while i anxiously await this update on Tmob...ive disabled a number of stock apps...would u recommend i re-enable everything before the MM install? Any chance it'll complicate/confuse the situation if i dont?
Android Central app on Moto X Pure
Are you not receiving it? If not, turn off the phone and take out the SIM and then turn it on and check. If you already did so, happy updating!
I just got the notification and downloading now. 652mb. Verizon
I havent got it, but i was under the impression tmobile and at&t werent getting it for a few days...
CrazyParis
