- Mar 9, 2012
- 169,695
- 11,114
- 113
So it only shows up when you go to that menu?
It's a good sign that it still shows up in Safe Mode. There are some situations where malware can be installed to the system root, which wouldn't go away in Safe Mode -- but that would probably require some of the risky behavior I mentioned before (i.e., sideloading apk files or rooting the phone and installing unsavory apps).
Try going to Settings>Apps, then tap Menu>Reset All App Preferences. Now see if the notification shows up again.
