Android Market
Ok I just installed the newest version, 3.1.3. and I still have the same issue as before, if there is only one app to update, I can click on that app, but then I only have the option to open or uninstall it, not the option to actually go through with the update. If more than one app has an update available, I can update.
Anyone else have this problem?
At times before the latest update, but if you wait a minute or so, the "update" button appears. Also since the latest market update, I have been getting daily app updates...much better than before.
I waited a while to see if the update button will show up, but it didn't. I did enable automatic updates then and a hour or so later it downloaded and updated the app. Still strange that I can't just update a single app, used to be able to.
Im contacting Sprint to find out why they refuse to update the Evos with the Market and Im getting nothing. I have no idea what reasoning there is behind this blackout. Ive already installed the .apk so Its more curiosity at this point.
I've been waiting and waiting, and finally side loaded the apk. Did you ever receive an answer?
I participate in several forums so I don't recall where but I read, fwiw, that it is Google holding it up and not Sprint. Doesn't make sense to me either. I installed the updated apk and have no problems.
I still haven't gotten the new market update for my 3VO. Unless I want to download the APK, which I have downloaded. I wanted to see if the 3VO would get it by itself, and still we are left out.
So I have updated using the APK file a few times now and for some reason after doing that and going to My Apps, the only things listed are the Youtube and Google Maps. I have cleared my cache and Cleared data and still won't show the rest of my apps. Anyone else having that problem and figured out how to fix it?
Apps now showing up in market has happened to me a few times on the old version. I have found that powering off the phone and back on fixes that issue.
Do you have second gmail account (besides the main one)? bcuz this happend to me and then i found out that the accounts switched and it was showing the stuff installed in the second account, which was nothing. When i changed it to the original one, all my apps appeared again!!!
I've got the new market and I didn't side load it. Is it being pushed out now?
The new market seems to work fine for the most part. I manually updated as well since I got tired of waiting, but one issue remains.... after some apps are updated, the same app may pop up the next day showing that there is an update available for it again. When you try to update it, all you can do is open the app or uninstall it. Once another app comes up with an update, then you can click on update all and both apps will update. I think this is just a bug, albeit, a rather annoying one. Skype updated, and right after it was finished it wanted to update again.
Hope they fix that soon.
Vera135
