Android N with Android Auto Maps
The telephone is connected to a USB port on the auto. My auto (Chevy Volt) has two USB ports alongside the 12V force port.
AA has been working fine for me with nearly the same setup, 2017 Volt and a Nexus 6P. The problem with DP4 was cleared up with the first update to Maps, I've never had a problem on DP5. I suggest that you do a factory reset on your phone if you are having problems.
Casperxx99
