Android O for the Pixel and Pixel XL.
Can anyone log in to their WellsFargo app?? I know im using the correct password. But it keeps telling me "An unknown error occurred. Please try again later."
Not working for me either. I'm guessing it's the app and not O as every other financial app I use works correctly. I hope they fix it soon.
I've been on O from the initial release, so thought I would share a couple things that I have noticed.
1. My Bluetooth is fixed! Audible has not skipped on my commute since the install. This alone has been a huge gain.
2. Battery life for me is the same or better. I have an XL, and have been very happy since getting the phone (at launch), so this is a good thing.
3. Notification shade is better and more functional. I am still getting used to it, but an overall advance.
4. The do not disturb functionality is not as easy as it was. It takes extra steps to turn it on for an hour, my most common use case. I have accidentally left it on several times now.
5. Lock screen notifications is a step back. I don't think all the kinks are worked out yet, so I am withholding judgement.
6. Ping ID is not working for me at all.
7. AirWatch is working, but I get errors.
I also like the look and feel. Animations and other tweaks have an overall positive impact.
I hadn't noticed number 4 yet; that one really is a bummer.
If you select the arrow, you get the option for an hour, but if you press the button itself it acts as a toggle
Well, not exactly.
First of all, I always had the DND icon in the top of the bar, so a partial dragdown of the shade and then tap the icon to get to the options.
Now, you have to drag the notification shade *all the way* down to get to the arrow, then tap the slider to turn DND on, and then choose the options.
It is definitely more work, especially when I am heading into a meeting and need to quickly silence my phone for a pre-determined amount of time.
Well, not exactly.
Yes, you are correct. One can also pull the notification shade with two fingers to get to the rest of the toggles. I also miss the old ambient display
Well, not exactly.
Exactly this. It is annoying because I thought the New implementation was spot on.
Lol.
I think the point is, it was easier and simpler before the change. There is no way that any reasonable person would say that DND is better in O (beta) than it was in Nougat.
Exactly!
It was really a simple point. I cannot believe the number of responses to it.
With a number of good reports on the BT front, I am jumping in.
I'll report back.
I have used my camera heavily over the last couple days and have experienced some significant lag in launching and freezing during video. This is pretty severe. It is clear to me something is hanging.
I'm not on Beta O on my Pixel
Im on 7.1.2
I use the Wells Fargo app daily and have no issues logging into it.So it might not be the app .
ahmedhadeethy
