Android Q Beta Bugs Discussion
I can't see any way to block a number under Q. If I tap call history and then the number, there is no longer an option to block. Am I missing something?
Just updated as I have no self control.
Anyway, it's only been 15 minutes but my ad blocker, adclear, doesn't work. I'll continue to poke around later.
for the estimated adapter battery savings here is what I don't get about Android Q. You're too screenshots I took one of the shortcut for the battery savings by the battery icon in a notification bar come and the other one is in the battery menu. Both have different estimates.
Mine shows 11:45 and 3am respectively. Clearly its something that needs to be worked out.
Adblock Browser https://play.google.com/store/apps/details?id=org.adblockplus.browser
Chase https://play.google.com/store/apps/details?id=com.chase.sig.android
Files https://play.google.com/store/apps/details?id=com.google.android.apps.nbu.files
Tactio Health https://play.google.com/store/apps/details?id=com.tactio.tactiohealth
These are the four apps that haven't worked for me under the Android Q Beta.
Waze https://play.google.com/store/apps/details?id=com.waze started normally but I didn't try navigating with it yet; an earlier poster mentioned that it didn't work for him?
Another thing Im noticing is that my lock screen is absent of information other than the clock in the middle and battery top right. No more date or weather.
Date and weather show up fine on my lock screen. Pixel 2 XL with the Android Q Beta.
I don't think you're missing anything - I don't see it either.
Be sure to use the Feedback app to note that.
Its following you along your route? Mine didnt budge from where I started. When I got home, it still said I was at work and would arrive at XX time.
I interpreted your comment as though the app wasn't bringing up the actual route; I haven't had a chance to actually go anywhere - just observed that it showed the correct location and route.
When I get a chance to go somewhere I'll check it further and let you know.
Ok, so I'm trying to diagnose the issue I'm still having with Android auto in my car after installing Android Q beta last night. The second I connect my pixel 3 XL to my according sport 2.0t via USB and load up Android Auto, Google maps or Google play music crashes within 10 seconds. I just tried to run Android Auto straight directly on my phone, and it works absolutely fine. I restablished from scratch all the connections again in my car. Does anyone have any suggestions? Thank you so very much!
I have been having intermittent AA issues. Got this one on the way home tonight (see picture). On a side note, I had a random reboot into the black screen today when my phone was just sitting on my desk. Screenshot_20190314-201012.jpg
Took a short trip to a nearby store and Waze worked fine: showed my speed and location; spoke the navigation corrections and rerouting at the appropriate points; it all just worked as expected.
Damn. This is frustrating because I use Waze daily. It is just not working for me.
FahadsTech
