Android wear 2.0 where is it !!!!!
Yes I have the $10 a month plan for my LGU2,l on AT&T. I also get the "already up to date" response when I try to check for software updates. Perhaps AT&T is the holdup?
OK, thanks for that. I was just wondering if always having my cell radio turned off was the issue. I figured it wouldn't be, but it was starting to sound like only a few of us missed the train.
Side note, I found an XDA post for forcefully updating APN's for switching cell services. Gonna set mine up with FreedomPop after I get the 2.0 OTA (if I get it).
*Small disclaimer* for mentioning both the XDA post and FreedomPop. Know what you are doing if you start flashing and DEFINITELY know what you are doing if you deal with FreedomPop.
Anywhere I bring up FreedomPop I add this info. They purposefully plaster FREE over everything, then design their system so you WILL FAIL to get all the fees turned off. It is possible though, and you can get a sim with 700mb data (only data for watches) for a one time purchase of $6. You just have to turn off like a dozen "free trials" they start you out with and disable auto-topoff.
I was finally able to update my LG Urbane 2 on 9/11. Like many of you when I would check my Urbane 2 for software updates and it would always show that software was up to date. After several days of researching every website I could find I stumbled on a article for updating the Huawei watch I found a comment about tapping the Software Up To Date repeatedly until it shows the download. Make sure your WiFi is on and when you get to the download screen I found I had to keep tapping the edge of the watch face to keep the screen active until the download was completed. Now I have a Urbane 2 with AW 2 and I am loving it. It was frustrating waiting and then figuring out how to install it but it was worth it! Hope this works for ya'll.
I tried the repeated tapping, but sadly no luck. My LG2 is a Verizon LTE model. Perhaps they don't have the update yet.
I have the AW 2.0 on my Huawei watch and it's a definite improvement.
This has been such a frustrating year for AW.
best part of update is that we now once again get call notification even when not connected to take calls on watch.
navigation will definitely take some getting used to. it doesn't seem as intuitive as before and requires more swipes and taps
seems to work great so far. over 9 hours off the charger and still 83% battery (cellular off). hopefully get to try it on a run this weekend with GPS, cellular, and BT music
On AT&T and getting mine now.
I forget what my source is (sorry), but the 2.0 OTA was apparently a "carrier" update, which explains the holdup. Seems the updates after that with the Aug security patch were through the play store (for me and some others), but also may have been re-pushed through carrier to get people from 1.5
lphilpot
