Another October Update For Battery Improvement
Do you have anything to back that up like comparisons etc...? Should I clear system cache after I install the update?
Usually don't have to clear cache unless something acting up , to back up thats its battery improvement ?
But how do they know that battery life has been improved.
Because that was one of the update improvements.
Are you saying your battery life hasn't improved since the update?
Have you given it enough time?
Have you checked what's consumimg your battery?
I don't see anything mentioning a battery improvement
The battery improvement was mentioned in the release notes for the European update, but not for the US, so the improvement is probably only for the Exynos phones. The European update versions end in U1ATJ1, whereas in the US it's S1ATJ3. An S in that position in the firmware version indicates that the update only contains a security patch. A U indicates that the firmware update includes feature/system/stability improvements (and may include a security patch too).
I already had the security patch since October 4th so that couldn't be it
The Android Security Patch Level (in this case, October 1) refers only to the security patch released by Google. There are also Samsung-specific security patches that can be released separately. So even if you already have the October 1 Android security patch, you can receive a second security-only update that's still at the October 1 Android Security Patch Level. That's what we have now with N986U1UES1ATJ3.
Probably still making its rounds , its available through odin with frija if your interested.
Never done it before. Wouldn't mind trying just don't want to brick my phone. Waiting for the beta also. Might try the Google fi Sim tonight, if not I might look into Odin tomorrow.
I can help if you end up trying odin , it won't brick your device because your flashing stock Samsung firmwares. I'm waiting also on beta :)
Hey curious about something. Does the beta have the battery update that was to be pushed to our devices, but that, those of us with unlocked didn't receive?
jossbuttler
