Any way to see signal strength in battery usage?
PAC757
Trusted Member
Mar 1, 2011
875
Hello, I haven't owned an LG phone in a long time, on most other phones you can tap the battery usage scale and see a history of cell signal, ie.. Red, Orange, Yellow, Green. I can not find anything in LG's software that shows that. Is it hidden someplace or does it not exist on LG software? Thank you in advance for any information.
Signal strength is not listed under battery usage
But it's a significant part of It.
The signal bar indicators in the status bar is a good sign for you to know how well and how much it impacts the battery.
I found the stock signal indicator on this phone pretty unreliable, sometimes it will show 3 bars and be actually sitting around, - 118db, other times it will show 1 bar and actually be at somewhere around - 84db.
I'm not disputing that it does not impact usage... Just stating the facts
Try GSam battery monitor. The stock battery stats do not show signal strength graphs but GSam does.
David
