Anyone else using Dbrand Skins?
Does anyone else with the Pixel or Pixel 4 XL have any issues with dbrand or slickwraps sticking to the back of your phone? I've installed both brands and both of them start to pull away from back around the edges. It literally is happening after a day on my phone. I've properly cleaned the back with alcohol before installing them. I'm thinking it's the material of the back that causes it to not stay on. I've never had any of these issues on glass backed phones. It's kind of frustrating. I'm also using a rhino shield bumper case with it.
I have a Pixel 3 XL, I've never had any issues with my dbrand skins peeling off my back either.
It could be the rhino shield bumper that is causing it to lift around the edges. I may have to put my caseology clear case back on for a bit. It only starts to lift around the camera bump.
Yep yep I mean my skins bubbling a little bit but not much on the bottom.
I'm not having any issues with my brand skin coming up along the edges, I'm using a Spigen case.
Inspired me to go full body ... Going to run with it just this way no bumper
Received mine a week or two ago, just got around to installing. It went on ok until I got to the Google G. That little insert was not die cut correctly. Half the letter G was not cut and trying to remove destroyed the G. Small matter, but it means I won't purchased again. I'll send them an email and see how they reply and may change my statement and feelings.
Didn't your kit come with several G's in slightly different sizes? Both of mine came with 4 or 5 letter G's to find the one that fits best.
Yes, however none of the Gs were die cut. I attempted to remove two Gs but that was impossible without ripping them and that was finding them by feel due to it being carbon black Gs. You could not even seen them, but pinching and rolling the paper did show where two of them were but as stated, they ripped.
Reply back from dBrand was take a photo and send it to them. Really, all a photo would show is a black piece of film where two white spots (ripped out Gs), but the biggest problem is that sheet is back at my house and I am far away from that house, will be for some time; so my reply to them was not a very simple explanation "I am not anywhere near the sheet to photograph, I will not be for some time, and I could really care less about the G. However, I can guarantee, I will never purchase your product again; not cause a mistake in a sheet was sent, but due to the idiocy of wanting a photo sent which implies I am a liar."
In reality, I don't miss the G on the back of the phone. And will most likely rip off the skin in a months or two anyway going back to the original white. There are other skin companies.
winarto
