Anyone experiencing instability with ICS on the 300?
How do you do the "factory reset" on the Asus T transformer 300t? Thanks!
There are two ways.
One is to go into settings and scroll down to Backup & Reset there is an option for factory data reset.
The second way is a total wipe and reset.
Power off, then holding down the volume down button, press the power on button.
When it turns on you have a few seconds to change options.
Hit the volume up so that 'wipe' is highlighted.
Then accept.
It will wipe and load original Tom, just like you got it out of the box.
But if you have rooted or used a custom rom the procedure might be different.
I just received my Nexus 7 and it confirmed my feeling, I have a bad unit and Monday I'm calling Asus and sending in the TF300T hopefully to get replaced.
Rob has sent this from his Nexus 7 using Tapatalk 2
Doris King
