Anyone experiencing problems using Nova Launcher? [Note 5]
Issemann
733
4
Within the past few days, something happened where Nova Launcher just freezes up for about 30-40 seconds - or sometimes totally locks up. I'm not sure what's causing it though. There was a recent update to TeslaUnread, but these issues are still happening even after uninstalling it. Using stock Touch Wiz has no issues. Anyone else experiencing the same?? :confused:
I have both installed and works great on my Note 5
Maybe uninstall Nova (I know you've done this already), reboot, and then reinstall...
Also, when you reinstall, DON'T restore your Nova settings. Use as is for a few hours, see how it operates, then, restore your Nova settings. Maybe something in your settings, is causing an issue.
I found the problem last night.... It was the Google Now widget. Once I removed it, everything went back to normal! 😊
The only issue I have was the unread email count. Every once in a while, it would show 999+. As soon as I launched email, it would correct itself. I haven't seen this occur since the tesla unread update.
Just got a note from TeslaCoil Help stating that this is a known issue with their beta version of NovaLauncher. So you can opt out of the beta program and revert to the stable version to get rid of the issue. :)
avromo
