Anyone having problems with Smart Settings not working consistently?
falc39
Active member
May 29, 2015
39
I love the idea of smart settings and I have 4 of them active. I also manually set where my home is in the settings. The problem I am seeing is that it is only working sometimes. Sometimes I have to check and manually turn off wifi and the other settings because it's still on when I get to work. Or sometimes I get home and the settings wont change until an hour or two later. Other days it works great. Smart Settings is a great idea but not as reliable as I hoped. I have my GPS set to the most accurate setting if it matters. Anyone able to get it to work more consistently?
It never worked for me.
I set it so the phone would go mute when I get to work, but it's never worked. Don't know if it's a bug or what, but I've never had it working for me.
Mine never worked at all for a long time; now it seems to do it from time to time. But, like you, it's inconsistent.
I have a few places set under Smart Lock and all of them work most of the time. There are times when they don't. Probably has something to do with the GPS.
Sent from my VS986 using Tapatalk
Jokerman
