Go to xda and download the att vvm app. Proof, you have vvm. Works on my One X.
Sent from my HTC One X using Tapatalk 2
Thanks for the heads up. Works great and looks a ton better than the 3rd party solutions
Thanks for the heads up. Works great and looks a ton better than the 3rd party solutions![]()
When you tap on the app in Astro choose open with App manager. Also make sure you check
The box in settings to allow apps from unknown sources to be installed
To be honest, I'm still on the fence. I think, yes his might sound weird, but, I liked my Skyrocket better. Not sure why exactly yet...
Yes, the WIFI is an issue, but try setting it to 2.4GHZ, versus auto (from the One X). As for the email issue, you have to go into the settings for mail (if you use Gmail), and set the mail notification for ALL email, not just the first one.
I had the same issue yesterday
Could some one post a link to the ATT VVM??
I love this phone.. it basically runs circles around any phone out there.. I know the non removeable battery and no sd card slot are a major flaw.. other than that this phone is ridiculous
You do have auto. Sync ON in accounts and sync, right?
And in that same page, you have tapped your Google account, and checked all of the appropriate check boxes?
There's more to sync than just logging in.
And as far as anyone can tell, best wifi performance does nothing but burn through your battery faster. It is not the issue here.
