- Dec 4, 2012
- 35,661
- 670
- 113
Rooting will not be an option for the AT&T and Verizon carrier minority variants as, if not initially, they will render their models, as per previous versions, unrootable, among other things.
Since I discovered Adguard, there is no reason for me to Root my phone now.Blocking ads in apps and everywhere on my phone was why I rooted but Adguard does this without root.
It's also nice that I won't void the warranty.
Adguard has the drawback of a notification that you can't get rid of. That's my biggest complaint about it. It works very well, though.
most definitely!! unl data plan use my hotspot as main source of wifi for all my devices
It's been confirmed on XDA that the bootloader is locked down on the T-Mobile and Sprint phones. This doesn't mean there can't be a root, it just means they have to look for vulnerabilities the same way they do with Apple devices and get in that way.I'm on the fence. We don't have Samsung pay in the UK yet but I'll know that I'll really want to use it regularly. But there's some root features I want to use, like ES file explorer root options and xposed force use of 4G. Gah!
I also have unlimited data and I use an app called FoxFi that is under $10 and does not require root access. It has worked perfectly and Verizon does not see it.
I think people are reading too much into the battery stats where they think the top 2-3 items listed there are killing the battery. I have two phones here using Adguard. One lists Adguard at 23% using 417 mAh, the other is at 40% with 1007 mAh and Android OS is up there at 31% at 734 mAh. Both of these phones last me more than a day on standby and give me between 3-5 hrs screen time. I don't think the amount of battery being used by Adgurd is anything to worry about considering it's always running. You can turn to on and off and use it only when you are using a browser or wanting to block ads in a certain app. Nothing says you have to keep it on 24/7. I just don't think it uses enough of my battery to worry about considering what it's doing for me.I'd been trying the Adguard free trial the past couple of weeks, based on seeing your earlier mentions of it.
I'm not certain it is a battery saver, though it surely seems like it should be. What's your opinion on that?
My experience is that Adguard was routinely showing as using around 2% (never less) of my battery each cycle. Chrome Dev is almost always the top app in that breakdwon, and it remained so. Other apps didn't seem like they noticeably dropped in battery use (though a small drop over many apps could obviously make a difference and be unnoticed in a quick look at the battery stats). I didn't perceive any obvious overall battery life bump, either.
What has your experience been?
Also, if I do purchase a single use license, is it locked to one phone, or one phone at a time? That is, could I use it on my G4 right now and switch it to my S7E when I receive it?
Thanks for your help.
