Anyone taking theirs back?
Like others have said.....HELL NO!!!!!
Best Buy does have a limit. Apparently, I have long gone over that limit by so much that I was asked not to buy another phone from a particular location because I had returned so many.
Sent from my iPad using Tapatalk HD
That's gotta be pretty embarrassing.
I had waited to get the sg3. I had the sg2 previously which I was happy with . I tried it for a few days and returned it and got the EVO 4g LTE . I haven't been happier. I'm not dogging the sg3 I just like the new EVO way better.
Sent from my EVO 4G LTE
I also made too many returns of various products and told me I have To wait 90 days
To get your back up assistant to work, you will probably have to do a hard reset. That is what I had to do when I went from my Tbolt back to my Dinc. earlier this year.
Sent from my SCH-I535 using Android Central Forums
just tried that and that didn't fix it .... still comes up invalid pin - and when I click 'forgot pin' gives me the one I'm entering....frustrating --- it started the day I reactivated the old phone...argh!
Thanks CarFan - I returned mine via mail yesterday, yes you have to return it the way you ordered it -- went to a Verizon store on Sunday to have my old BB reactivated, which went fine except - now for the Backup Assistant I keep getting a pin error......argh -- says my pin is 'invalid', when I have the pin sent to my phone, it gives me the one I've been using....tried to set new pin, but still get old pin invalid...will have to contact Verizon about that, or maybe try uninstalling the app and reinstalling....frustrating!
I prob should have exchanged it for a new BBerry, but decided I didn't wanna make a 'rushed' decision again- have read a bunch about the Bold 9930's 'bricking'....so maybe I'll hold off and see what the next BB will be or just keep mine til it dies then figure out what's next :)
You're going to be waiting a long time for the next BlackBerry.....I've used BB for many years and I hate to say it but RIM is dying slow death. I honestly was tired of the lack of apps and a small screen.
ok - had to go and 'uninstall' it thru the Apps manager, then re-install it -- seems to be working for now :)
yea, I know.... but for now the days I get out of my battery and the immediate 'push' emails (I know Gmail pushes, but to go and change prob close to 150+ accounts would be a big pia for now)....I can use my iTouch for the apps thru wi-fi...
Wuiiytka
