Anyone tried V6 SupeCharger?
I also chose option 8. Does this automatically run and work on every boot, or do I have to manually load the script? Should I use ATK with this? Not sure what this actually does, but phone did seem a bit faster.
If you using ATK to kill tasks..STOP NOW!
ATK was wrote before android included a built in task killer and before the release of android 2.0. It was wrote and put out in the wild to supplement a missing part of android which was the ability to kill tasks manually. Now since 2.0 came out there is no need for a task killer app like ATK android has the code built in and scripts like the one posted optimize the rate at which android decides to kill things off.
What this script does is optimize your settings. The stock android settings are nice but they are designed for a generic phone base. This script optimizes some settings and makes things more stable and less likely to crash.
Uninstalled. Phone randomly started playing music at boot and screen was unresponsive. Had to pull out battery.
wow. you must have done something wrong with the install?
my phones running better than ever with this mod, and thats not just a percieved placebo effect. doing things that killed my phone without this mod dont even affect it now, its weird, its a completely new phone.
Which # option did you select? I chose #9.
Has anyone tested the 3g supercharge? I applied it, but I get little to no 3g at my house so I don't know how well it works
I do have to say this does make a huge difference on my phone, my phone is running smoother then it did with reborn, I am currently running backside with xionia redux
I usually get around 200-350 kbps 3g download speed, I would never get up to 400 kbps. I did the 3g supercharge and got around up to around 300-500 kbps. I have low 3g signal at home. All it did was add a few entries to the build.prop. I also did the kickass kernel tweaks. Im on bumblebee 2.4. Since the scripts are already installed can I uninstall the script manager?
Would we have to apply this at every boot or no?
It specifically says several times NOT to do that. The changes it makes are there until you reverse them running the script again. It's unbelievably easy to use. Just download the script to your SD card, run the script with the recommended program and read the instructions. For realz yo! Even Jesse Pinkman could figure it out.
Reactions: steven1droid
this looks exciting. i won't be able to try until i get home because for some reason, my phone can't download it.
for those who have it, do you have any specific examples of what programs might run better/smoother than they used to?
thanks!
How would you go about changing what option that you are using? Do you just run the script again and choose that option or is there like a removal script or something?
yes just run it again and choose a new option. There is also a undo option. If you want choose it reboot then pick the one you want.
Just run the script again and select the new option. I chose 9 I have no idea why but I just did. So once we install the script, do we still need Script Manager? Can I uninstall it and the mods will still work?
OK I think I have it installed but I don't get any options to choose from and when first ran script said couldn't find using bz box 1.18.2. But did give me more memory
I had to install the scripts on my computer and move them to my phone to get them to work for some reason, try that
TheGreatApe00
