AOKP settings
There was like a kernel reset. I believe faux did it. I'd have to check back and am too lazy right now due to tinkering w/ MORPHR + S Corps class lol
Oh.... Je ne sais pas, mon ami
Maybe it is in my head but since switch to Francos Kernel from whatever i was on my battery is not draining as fast.
Here is my settings:
Kernel: #133 (Franco)
Max cpu: 1228 MHz
Min cpu: 384 MHz
Governor: ondemand
Generic Hotplug, Dual core (CPU mode), SQlite, Turn logger off, Enable Fast charge all checked.
This resulted in fantastic battery life.
I just installed AOKP ROM and have Francos Kernel installed (previously). My battery life seems to suck right now. I switch to battery percent vs bar so maybe it is the life is the same and having the percent is throwing me off.
Any recommendations? What should I be playing/tweaking with? Also what should I be adjust the voltages to? I tried to get info but I feel I am on an Easter Egg hunt trying to get information lately. So if anyone can help out it will be greatly appreciated.
***EDIT***
Even though I had Franco's Kernel Updater I was not actually running Franco's Kernel. I was running something else (imoseyon) and I did not realize it. I probably still need to wait a few days but my battery is not being sucked dry now.
I'm using battery text instead of icons and hoped that would give me a more accurate reading. In some cases, it could be radios that are causing battery drain and not apps if your phone is constantly searching for a signal. What I started doing was turning off 3G when not needed, especially at night. For example, went to bed with 41% BL and when I woke up five hours later, I was at 40%.
joshchild106
