ApeX 1.3.0
How can I get the most out of my battery tnt?
Best to save is try the stock 1.0 undervolt. It drops the lowest slot 2 volts. If your running ok you can try and lower the other slots. Got 1 day 11 hours the other day on the preset stock low voltage.
Sent from my DROIDX using Tapatalk
Any tips and tricks for a newb wanting to take advantage of the terminal emulator on this rom?
I just use it to push new apk files. If I want to try out a new keyboard I put the LatinIME.apk file in root of sd. Then open terminal type su then hit enter. Then type install LatinIME.apk then enter. Easy way to install new things to the system.
Question for everyone, so I accidently dragged an app into the drawer space on the dock, now I can't seem to get it out, tried reseting and restarting adw, but nothing, long hold nothing, I know I can drag another app there, but doesn't really help me get the drawer open, thoughts?
Long press on the home screen. Select shortcut, launcher activity, then select app drawer and move that to the dock.
I personally have my swipe down action to open app drawer... then you can put five apps into dock.
Swipe up to hide top bar...
Create a CUSTUM SHORTCUT on your descktop....custum shortcut/pick your activity/Launcher actions/open close app drawer.
you can pick your custom icon as well.
Once set up just drag that baby to where the drawer shortcut usually goes (smack in the middle!) It will override anything you have sitting there.
Close enough! I realized I just switched to the Zeal launcher and couldn't check to make sure. Though I could have switched quick with home switcher. Well hind sights always 20/20. Luckily there's a Jedi to keep us honest!
I noticed after flashing this ROM, I cant send emails. Recieving just fine. Anybody have/had this issue? Suggestions?
Is anyone else having a problem keeping twitter's data synced using apex 1.30. I have the offical twitter app, my accounts say its linked, but when I click on the app's settings and click sync, the second i change screens it goes back to unsynced...
Run under voltage (1ghz)
TNT that's not an option for me. The options are from the presets...
100% stock (1ghz)
Stock voltage (1.1ghz)
low voltage (1ghz)
Then the rest are like 1.2,1.3,1.4, 1.45 ghz
100% stock (1ghz)
low voltage (1ghz)
Lol sorry no sleep. Its low voltage one
Can I install this like I did 1.3? (Download it on comp, put in root of SD card, clockwork reboot into recovery and install from zip file?
Also, how do I make a backup? I just make it using clockwork in recovery mode? I did that yesterday installing 1.3 and it seemed to work, (I have a backup folder now on my SD card) I just want to make sure.
Thanks!
Thanks!
Yes flash just like 1.3 I had some issues not sure why. See other apex 1.3.1 thread. And yes backup the same but if you made one yesterday your good.
carmilane
