ApeX 1.3.1 on Droid X!
I'm back too. Feel a little dirty about it....flirting w/ other roms that is,lol.
Anyway I noticed on my phone that the overheating was coming from me Undervolting my phone. It appears that the processor wasn't getting enough juice, so i was actually making it work harder. Since I've put it back to stock voltage the OVERheating has gone. Sounds weird I know...but try it out. I haven't hit 100 F since.
Wow... I've never hit that high. The only time it got into the 90's is when I have little to no signal and it's working to pick up reception somehow while I'm using it.
I replaced the keyboard to the black keyboard from Prefer Black Above White? Get a Black Keyboard for your Droid X | xda-developers
MAKE SURE YOU CHANGE DEFAULT KEYBOARD TO MULTITOUCH BLACK DEFAULT
attachment.php
attachment.php
This is nice! Is this the same keyboard found in Rom Manager (WJD Designs)?
I was getting 105 just downloading apps from Market....Something was way off there.
My first big problem with this ROM happened at 6:30 this morning. I use my X as my alarm clock and it has always worked...like always. Then, I wake up this morning to my wall clock showing 6:30 instead of my usual 5:30am. Lo and behold, I look at my X and it has a Force Close for "Android Process". This is the 6th or 7th time this has happened in the past week and a half. I am very upset about it and hope this bug is ironed-out in the future. Looks like I'll be using a backup alarm now, as well.
Yea that's definitely not normal at all. There might be some other settings enabled that could be causing high temperatures. Maybe try a wipe of the phone completely and a fresh install of ApeX, then reconfigure it. When you restore the settings from a backup, whatever is causing the high temperatures is coming back with it.
That's unusual. All six or seven times it's been the same exact thing?
I just wiped cache, so we'll see if it fixes my problem. If not, I heard installing from ROM Manager helped some people...
I am unsure, I just missed my black shiny keyboard and decided to give it a try and was happy it worked, now I am hoping to be able to find a port of 928 Droid X Black Glass theme for Apex rom and then I will be in heaven.
I've not had a single issue with the Apex rom.. alarm works fine, no force closes at all, downloading/installing apps from the market works fine.. battery life is great and it's super smooth.. guess I'm lucky.
Let us know if you find a way to do so, I'm interested in having that theme as well.
Try clearing the data on the market app under Settings >> Applications >>> Manage Applications >> Running Tab >>> Market
Reactions: JkdJedi
im back as well. the fact that my phone would reboot when ending a call sealed the deal for me to come back to apex
In Rom Manager select Fix Permissions. This seems to have helped on similar issues for me. WILDMAN I erased data in Market, that cleared up some apps not updating.....thanks.
Sent from my DROIDX using Tapatalk
I've done the fix permissions before and it did seem to clear things up, it does take a while though.
DL'n 1.3.1 from ROM manager... does it require a data wipe to install the update,coming from 1.3.0? I'm not really sure... skatedawg, we're gonna get you some results here,buddy
DXmeatclaws via talkatap
No wipe is required if updating from 1.3.0, I updated without the wipe and it worked fine. Full wipe is only needed if coming from a different rom.
just wiped the data associated with my aosp gallery program and noticed that the phone (over the slower wifi connection at work) spent a couple of hours re-downloading data associated with my many picasa web album pics, getting a bit warm doing so and using a fair bit of battery. for me, that's well worth the energy consumed (having picasa associated with the pics on my device relatively seamlessly). just thought i'd mention it for those who experience poor battery life. you may want to let the device run a day or two as-is and see if it improves.
I have a question. On the latest handscent update it says better support for apex rom.
Anyone know how they support it better by any chance?
Jokerman
