ApeX 1.3.1 on Droid X!
User error on my part with terminal. Note to self don't flash and try updates with 2 hours sleep.
Sent from my DROIDX using Tapatalk
Microbes live wallpaper is neat. Touch the screen to feed them things.
Still having overclock issues. Hit the overclock button on unstable app and it quickly reboots still. Tried the terminal script and it froze at low 1.2 that worked on my app. What's everyone doing on this?
FIX: ok run the script in terminal and set up the stock settings. Then you can open the oc app and go at it.
Wow... im perfectly happy with 1.3.0 for now. Looks like people are having minor issues with 1.3.1.
Another note... where did you find that microbe live wallpaper? Is it in the marketplace?
Its a add on for 1.3.1. Its neat. I only really had a oc app issue but worked that out. Backup what you have now and try out the update. No other issues for me.
tnt i was having the same exact issue with Unstable OC app. How do I fix it? I've never done anything with scripts. My Quadrant scores are lower with 1.3.1 :\
I was planning on getting either Unstable or Jrummys OC app, is that going to conflict with anything? Are there any major performance changes or major changes in general?
Open terminal. Type su then enter. Type overclock then enter. Select 3 then enter. Select 10 enter. Then select 11 to exit. Your oc app should now work no issues.
Reactions: kajii
Excellent. Thanks for that tnt. I'll have to try that.
can you possibly throw me a bone with my messaging app? I posted a comment 1page back w/screenshot
DXmeatclaws via talkatap
thanks bro, you rock :D
Edit in the oc. Don't set your app on boot. Will have reboot issue if you restart your phone. Ill look at it more later. Just if you reboot just open app and set your preset.
Like this?
Root explorer. System/app. Find mms.bak and click and hold. Rename mms.apk. that's the stock tex mess app. The blur one is the one your using now.
Reactions: sicario666
Hey I really like that microbes wallpaper can someone explain how to get that. I am new to terminal would really appreciate if someone could write out the full script for me. Thanks
Like this?
YES! Awsome. youve saved me once again. i went ahead and conducted a test to wipe data n cache and reinstall. it didnt work. then i seen this post. im restoring now to apply the black messenger. thanks again tnt:D
When I install this new 1.3.1 rom from my sd card, can I do it right over apex 1.3 so it doesnt delete all my phone data and apps, or do I need to wipe the data and cache?
Thanks!
Awesome thanks so much, Im going to give it a try now! Well I think Ill first make a backup of what I have. When I create a back-up does that pretty much make a backup of my phones current state (apps and everything) or just the rom 1.3?
The backup will make it like you never did a thing. Just flash it and you wont remember doing anything you didn't like.
Reactions: victormolina15
jr212
