Apps that don't work on the Nexus 7
Any one got issue with YouTube, mine plays for around 2 seconds then buffs plays 2 buffs all through playback, play store say's its incompatible but it shipped with the device? (works fine on my phone)
Call of duty elite app works but you can not input your email/password
Mine are.....
Directv
SirusXM
Enhanced E-mail (exchange only)
HBOGo
Microsoft One Note (my most important)
I'm running Enhanced Email just fine; although I did get it from Amazon instead of Google.
Upon further review...
The email part of Enhanced Email works fine, but but the calendar sync only appears to work on recurring appointments. It doesn't seem to pull down or push up one-time appointments.
Apw widgets app does not work properly. You don't notice a problem until you change widget sizes by adding 5x4 or 5x5 size apw widgets. They do not appear in your widget drawer.
I emailed the creator for a fix.
UPDATE
They are resizable by simply clicking on the apw widgets.
Hmm...did a search on this thread and returned nothing. Would have thought someone would have posted this by now, but Google Wallet show not compatible with your device. You can go through the setup but always fails when you set up a citi mastercard.
Will look around for a solution.
It may not be compatible because I rooted my Nexus 7.
I got a warning about setting it up on a rooted device when I went thru the process. It did let me finish the $10.00 freebie, though.
Native gmail app not allowing attachments such as zip files to be downloaded on device... so I'm using Dolphin HD browser to access web gmail to download my attachments ...then I use a file manager to get at them...wow.
i am really confused, Amazon Mobile can not work, what a pity, i am desiring to buy things, i have to use my computer,!!!!!!! what about u guys!
CBS's radio.com app crashes within seconds of opening and choosing a station to listen to. Really wish the Corporate morons at CBS hadn't forced Tunein to remove all their stations from that app.
Yes it does. Sideload the Amazon Appstore from their website and install Amazon Mobile from there.
Pocket Informant didn't work on my N7. There are games that need to load to a SD Card but cannot because there IS no SD card. :eek:
Just use your Google chrome
I'm using PI now - seems fine with DPI set to 170 and default.
ADW EX Launcher will install but the shortcuts/widgets/folders appear to get "Stuck" between screens when you come back the app screen or any other app about 40% of the time - not usable IMO. Thankfully I discovered Apex Launcher which appears to be really nice.
Also, SunTrust still no joy on working.
Verizon FiOS Mobile Remote - The actual remote function of the app causes it to force close. THe DVR and other features work fine though.
Mass Effect Infiltrator does not work! It says it is not supported when you try and install :(
Very disappointed in that fact...maybe they will fix the issue or even better come out with another Mass Effect game especially for Android Tablets!
Cancel that, Mass Effect Infiltrator is now working!!
BBC iPlayer
Sky Go
Tiger Woods Golf (all EA Games?)
Amazon UK store (Getting from Amazon doesn't work)
Photoshop Touch
BBC Olympics
Bloomberg for Tablet OR Bloomberg for Smartphone
plus others that should be using the tablet app
Google Reader
Tweetdeck
BBC iPlayer
Sky Go
Photoshop Touch
BBC Olympics
Google Reader
Tweetdeck
If you set dpi to 160 or 170, Google Reader uses the tablet layout. Not sure about Tweetdeck.
uOttawaGrad_22
