Archived: [ROM[2.3.7]LeWa OS! 3.2.2
I was only able to find the themes in the sdcard, nothing on the device itself unfortunately :(
Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
It's weird, because in Themes, you have the Chalkboard theme that you can apply.
I swore I seen a post by Gannon about posting a post stating something like, " Makes Themes in the system directory........ Some themes are over 5MB's.... Be aware " Or something like that. :/
Reactions: rukin5197
Not exactly, but you were close. That was over at MIUI. Try looking in /data/system and see if there's anything in there that might contain it. If it's anything, it's in there. Lol
I remember looking in there. Nothing I saw. How did you make the default theme Chalkboard? I found a huge collection of themes and I want to use Glasklart(Might be misspelled) on LeWa. Other thing is the Ringtone stuff. Anyone know a app that can set Ringtones? :p
Ringdroid does.
Tapatalkin it from my IHO CM7.2'd, MIUI Themed Optimus V
Help?
I am trying to flash ROM, and it cannot saying that it cannot find: system/media/audio/notifications/electra.ogg
what should i do? Would just copying another notification sound and naming it electra.ogg fix this problem?
Help?
Could be a bad download maybe try redownloading and flashing again
Im getting som random reboots..all cpu settings left at stock. Also, every once in a while like after a reboot or when leaving wifi, the 3g wont work unless i go back into the network settings and open up the cdma name setting option then close it again even though the checkbox remains checked. ANy fix for this? Other than these few bugs i am loving this rom :)
oh i have downloaded it three times and tried re flashing multiple times. still no luck. still saying it is missing that file, i even tried if from a different sd card
How do you split messages? I cannot send messages over 160 characters with the default messenger app.
Isn't it the same messaging settings as the default?
no the only settings i have from the default messenger are:
"delete old messages"
"text message limit"
"multimedia message limit"
"Delivery report"
"sms realtime note"
"delivery reports"
"read reports"
"auto-retrieve"
"roaming auto-retrieve"
attacthment save folder"
"notifications"
"notification settings"
"send on enter"
"always show character counter"
"templates"
no options anywhere for split 160
"Delivery report"
"sms realtime note"
"delivery reports"
"read reports"
"auto-retrieve"
"notifications"
"send on enter"
"templates"
That's odd. :/
Hold down the menu key the one on the bottom left of the phone when u get to the part to enter numbers and entered ur texts, scroll down unchecked the split msg option and check return to all threads. Saves the extra work later on. hope this help.
SAVVYSCLUTTER
