CuriousNoob
Banned
- Aug 2, 2011
- 1,590
- 202
- 0
Some issues come up with Market compatibility. Some apps won't show up even though I've installed them on previous versions.
This is due to the build.prop
ro.product.model=VM670
should actually be
ro.product.model=LG-VM670
This tells the market what phone you have.
If it still fails to show everything, then some of the Gapps files are missing or the Market is glitching.
Also on the APN settings should be...
Replace everything in the etc/apns-conf.xml with what is below.
<?xml version="1.0" encoding="utf-8"?>
<apns version="6">
<apn type="mms" apn="0" mnc="490" mcc="311" carrier="Virgin Mobile US" mmsport="81" mmsproxy="205.239.233.136" mmsc="http://mmsc.vmobl.com:8088/mms?" port=""/>
</apns>
That's actually pretty cool. Never knew the market reads that. o_o
After messing around, to get 3g to work, you have to go to
Settings>Data>APN>New APN> Name it whatever you want, and name the APN what ever you want>Save APN>Check APN
You will then have data.![]()
I tried the dropbox download link and it says error cannot find file
How do I get the hard buttons to turn off. They stay lit up
I am waiting for 3g on miuiv4 gannon so keep up the good work for us![]()
3g for miui works. Just still getting phone fc when you go to call someone or get a call. Working on it
Sent from my Amazon Kindle Fire using Tapatalk
