are you leaving the Note 7? if so, where are you going?
Status
Not open for further replies.
So minus not having Spen, you think V20 beats the Note 7 in most other categories?
No, not at all. I liked the v10, but I don't know what the deal with lg is but they can't get battery to work for anything since thte g2. I've tried the g3, g4, v10 and I can't get battery to last more than 3.5 hours sot at best. Deal breaker for me.
Waterproofing is big for me. Also like AMOLED, but I could be convinced to go back (I loved my G4).
I spend a lot of time outdoors and the S7 has been great for me..I was looking to the Note to be my bigger S7.
First the people that say a S7E screen is better than the note 7 needs to get their eyes checked I carry a note 7
Its already been verified that Samsung used a warmer temp for the display on the note 7 giving it a yellowish hue. Ive tested 7 note 7's at this point and there is a difference between the edge, active and note with blacks and color comparisons. Its slight but for those who pay attention to those things its noticeable, sorry.
Yes ^^ this. I'm a photographer so color temperature is something I definitely notice.
I was from G4 but I dun think I can go back after using Note 7 haha.
Only thing I missed in G4 is the double tap to wake and lock, and the non physical home button.
The v20 has a more durable design and has removable battery, (and a few other things that I don't think many care much about like audio). But other than that the note 7 is still better.
Many people seem to be complaining about the note 7 not being durable so that may be a big concern. The v20 still uses gorilla glass 4 as well. Would be interesting as to whether gorilla glass 5 even gets adapted by others, ATM its only the note 7 iirc.
Removable covers can help a lot to displace energy since they usually flex/give and pop off. The catch is that premise usually is for mainly plastic frame devices. The V20 apparently is mainly aluminum, so negates that advantage to some degree and the energy usually releases more through the glass instead of the cover.
Kind of torn, since my main issue is the apparently weak signal reception of the Note 7. It is at least 5 dBm weaker than the Note 4 and 10 dBm weaker than than MXPE. That is relatively huge and significantly impacts battery life unless mainly in a strong network signal area. I notice a huge difference with battery life if in 3 bars (100 dBm or higher) or less LTE areas.
If the V20 had better signal than the Note 7, I might consider the V20. Reason being the battery life advantage of the N7 amoled display is offset by the LTE radio draining more due to weak reception.
No interest in LG. I had the G2,G3, G4, G5 and V10. Only good one out of that bunch was the G2 IMO.
Going back to my iPhone 6s+, might consider back going to note 7 when most of the issues are resolved. Really enjoying the note 7 tho. 😭
Most issues resolved .
I have none, I think part of the problem is how people set up there phone they transfur everything over from a older phone then complain when sothing doesent work right.
Except for contacts and photos I did a complete clean install.
Maybe go for the new Iphone 7 Plus, in the new Apple color, simply called.............................................BLACK.
NOT!
I will wait for the replacement to come out and turn mine in and get the new one. Inconvenient? yes. A really big deal? No.
I might get flamed but after the key note from Apple that 7 plus looks awesome......We will see.
I still have my Note 7 on my line but might get the iPhone 7 on my wife's line and use both to try out and then return one.
Would think the side by side reviews will be out Sept 14/15 if the iphone 7 will be available on the 16th. Cannot imagine them selling out or long lines on initial sale day like years ago. Am curious how real world battery life is or will between the Note 7 & iphone7+.
Status
dumpsterrentals89
