Art vs Dalvik and battery issues
mobrules
1,170
I use the smart actions app/settings. It is set to disconnect all connections when my screen goes dark. Makes the battery last 3-4 days usually. I tried switching to ART and using the exact same settings the battery only lasted 24 hours on average. I didn't change any other settings. Using the application Better Battery Stats really didn't show anything that stood out. Has anyone had results like this?
Sent from my Nexus 10 using AC Forums mobile app
Better Battery stats might not be coded for ART. That might be the reason you aren't seeing any difference.
Very true. I was more shocked by the difference with the performance of the battery.
mom1988
