Asus 3 Max X008DA firmware issue please help me!
  • Start date Start date
A
Android Central Question
I am having a Asus x008da (Asus 3 max)
It is stuck in loading screen.So I decided to Flash it with SP tool Because it is not working with SD Card option and In ADB sideload
mode my pc is not detecting the device
I downloaded the firmware from Asus official website And when I loaded the scatter file I got an error
"ERROR:STATUS_SCATTER_FILE_INVALID(0xC0030001)
The scatter file format is invalid!
[HINT]:
Please Select a valid load or ask for help"
I tried another firmware from the asus official website but returns the same error
Plzz Help me.......
Windows is not at all detecting
means IT is not detecting even as a unknown device
If I plugin the phone it is just like a usb cable connected simply without a device
There is no respone from both the device If I connect in abd sideload mode
SO ONLY OPTION IS TO FLASH THROUGH FASTBOOT
for that i need a sp flash tool supported firmware
Let me ask this , does your computer recognize the device when plugged in ?
No, It is not recognizing in the adb sideload mode
But recognizes in fastboot mode
(Device is stuck in boot logo)
Ok that means , cables ,computer are good , sideload mode you need to execute commands and it doesn't recognize that , possible your adb studio or such needs to be reinstall or different version to work . Have you tried the 2 links that was suggested?
saifor
