AT&T 4.4.4 Galaxy S4 Download is ready
My battery goes from 100% to dead in less than 3 hrs and my phone is constantly hot. When its not on the charger just top half is burning hot. Then when charging the whole back of phone is hot
I'm seeing another new problem since I updated to 4.4.4, several times a day I get disconnected from my email (I use stock client with a verizon.net email address) and told signin failed, password on server changed. I re-sign in with the same password I've always used and it works fine. I do not have a Yahoo address, which I understand is messed up because now Yahoo and Verizon are affiliated - so I hesitate to do the fixes people have been posting for Yahoo email addresses. Anybody else having this problem with their email client? I know if I contact Verizon they'll say it is my phone provider's problem (AT&T) and if I contact AT&T they'll say it's my ISP's problem (Verizon). Sigh.
Are S4 users going to get Lollipop?
Sent from my Samsung Galaxy S4 (SGH-I337) using Tapatalk Pro
I can't ubdate my android to 4.4.4.I have 4.4.2 and when i check my ubdates nothing.why i cant have 4.4.4 on my samsung galaxy s4 gt i9515?
I've had 4.4.4 for a long, long time. I'm waiting for Lollipop.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
You need to increase the amount of available storage on your phone to install Lollipop. I made enough room for 3GB of available space. I did have about 1GB. You need to remove apps or move them to the SD Card. To see how much you have:
Go into Settings.
Select More
Select Storage
To remove or move Apps:
Go back out to the More menu again
Select Application Manager
Select an App
If you have an SD Card and the Move to SD Card is not grayed out, you can move it to the SD Card. Otherwise, you can Uninstall it.
Do this for all the Apps you have to make more room.
Go back to the Storage Menu
Clear your Cached Data
Try to reinstall Lollipop again. If you are getting the,"You must wait XX hours and XX minutes, go to Data and Time, Turn off update automatically and advance the date by at least 1 day and go back and reinstall Lollipop.
Just checked for software update and 4.4.4 download is ready. 392.48MB. Going to take a while! Finally! Now all we have to do is wait 6 months to get 5.0! If anyone has any problems downloading or after installing please let us know. Good luck. BTW, don't forget to wipe your cache partition after the download.
4.4.4? I just downloaded 5.0.1 last week. You're a bit behind for this phone. Surprised that that download was still available OTA.
byronsss
