AT&T Note 3: KitKat benchmarks?
Lookout seems to be hogging more battery than usual. Guess that will be disabled lol
Sent from my SAMSUNG-SM-N900A using Tapatalk
Try clearing its cache first, then if that doesn't work, uninstall, reboot then reinstall.
Re: AT&T Note 3: KitKat benchmarks?
I notice my vellamo number is way down...everything else is about the same.
- - - Updated - - -
Another interesting thing I noticed is that RAM went from 2.38 total to 2.71 total.
So I've had kit Kat for 3 days and I am noticing some reduced battery, my android services never used to be higher than 12% and now it's always around 25%. Kies is stuck on an endless update loop on my computer so factory resetting would be problematic, think it's worth doing anyway?
Yep. It's worth it.
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
Same issues, pretty much the same Kies 3 problems, but used some of the backup anyways, end result being noticeable improvement after complete wipe and re-install. It is worth it.
Sent from my Samsung Galaxy Note 3.
Oh...this is my benchmark. Not the highest but oh well.
Before KK I was at 32085. Afterwards I am now at 26039. I am quite leary of doing a factory reboot. Why should we have to do that for an update. Ridiculous.
I can't remember exactly and I wish I had captured it while on 4.3 but the score was 34 thousand something. As soon as I updated to 4.4.2 the score was 33716. After I wiped the device and re-installed everything the score went up to 35443. So what does that mean ? Probably not that much. It is just a benchmark but as long as there is no lag and everything is quick I am happy.
I'd sure like to know what it means. I'm north of 27500. So what difference between that and the 36000 bandied about upstairs? Why go thru the inconvenience of a wipe?
I just ran a benchmark and scored 27000 out of the box. Already setup my phone so no reset for me.
Except that they're getting 36000 after a reset. Does this mean they'll get faster processing, gaming, or web browsing experience than our "measely" 27000?
Ran again this morning and got 36500..not sure what difference since yesterday..
Did the KK update yesterday afternoon and got about 26000 on the benchmark test last night. Did a factory wipe/reset this morning and just finished re-loading my phone. Almost made 35000 on the benchmark test a few minutes ago.
So, per my above post you can see where I was about 9 days ago. Since then I've fallen back into the mid 26000 range. Seems everything is excellent on scoring and good on CPU. This was after doing the "big" cache clear and having nothing running.
alejandro109322
