AT&T Note 4 updating... looks like Lollipop
Forgot to attach this one as well.... I did have to do a quick car charge for 20 minutes as it dropped too low. Shouldn't be happening.
Google Now "always listening" seems to have been disabled for the Note 4 in the Lollipop update. Can't activate the device when it's locked & screen off. That's a deal breaker for me. I had this functionality in Kitkat.
Anyone have this feature working or know how to enable? Tried uninstalling updates to Google search app. No good, the default version has been updated in Lollipop with the functionality removed.
Works fine for me
Sorry...didn't want to post the whole post from Boufa... but am curious why the below were left off the note 4 on ATT.
Also is there anyway to get the multi user mode enabled? Or is there an app that would replicate it?
Thanks
Ed
2 - No flashlight from task bar
3- Can't "pin apps"
4 - No Multi User mode including Guests
Anyone having any charging issues??? Even tho fast charging is checked it doesn't look like it's fast charging if it's going to take almost 2 hours to charge the remaining 61%.
Disable S Voice in app management and then reboot. Always On will no longer be grayed out in Google Now settings.
Battery life and quick charging don't seem to be as good as before update
May do a master reset this weekend and see if it helps any...
Re: AT&T Note 4 updating... looks like Lollipop
Thanks
Ed
3- Can't "pin apps"
And still no data network toggle in the quick settings menu. This for me is am issue because Google broke the ability to use aftermarket toggles so now it's the ios like method of multi steps to do 1 simple task
I'm not sure what toggles you want, but Power Toggles works with this update. I use it to quickly toggle Wi-Fi and Bluetooth.
Restores are one great advantage that iOS has over android. I hate having to set everything back up again.
Actually any time I've had a problem with my iPhone where I've needed to restore it I have been advised by an Apple Store employee NOT to restore from a backup as the issue will likely carry over from the backup. IMO backups are great if you lose your phone or switch to a new device, not so much if you're having problems.
The AT&T data network. Every carrier but AT&T has a toggle in quick settings.
I tried that app, set it up, tapped the data toggle (up/down arrows) it opened my data settings instead of toggling data.
Thanks for the suggestion but Google is the one that disabled the ability for any 3rd party app to work anymore, according to Google itself.
Agreed. More times than not an app has gone rogue when things go wrong and a backup/restore only repeats the bug. Like doing a ghost write restore of your pc before removing the virus that broke it.
I just downloaded Power Toggles for my Note 4. I did not do the Lollipop upgrade so I'm still on 4.4.something. Works perfectly for me. Tap the data toggle and ut just turns off the data. With wifi and data off, nothing comes through.
Note 4
People with the update, do you have a mute option in the notification shade?
Do you mean during a call or silence the phone?
I still have the volume toggle that you tap one for vibrate, twice for total silence.
I use Rocket Dial for calls, has its own mute during a call.
Sorry, yeah the volume toggle is what I was talking about. pretty sure it was removed from Android in Lollipop so I was wondering if Samsung put I back in there or not.
Slow yes...but i have the 10000 MaH battery and its at 65%....so I should be good to go. 2% in about 2 minutes.
10 Minutes in....and at 10%
Gremlin69
