AT&T Note 4 updating... looks like Lollipop
Hold volume up, power and home button at the same time until it vibrates then hit wipe cashe partition then hit Reboot system now
Be sure and power the phone off before doing the steps above. I forgot and was having the same problem wiping cache.
Yeah sorry I forgot to mention that. After I cleared my note 4 cache it's been running silky smooth
Google Now "always listening" seems to have been disabled for the Note 4 in the Lollipop update. Can't activate the device when it's locked & screen off. That's a deal breaker for me. I had this functionality in Kitkat.
Anyone have this feature working or know how to enable? Tried uninstalling updates to Google search app. No good, the default version has been updated in Lollipop with the functionality removed.
Note: Disabling s-voice in app manager allows you to turn on the greyed out toggles in Google Now; however, this just lets you activate Google Now when the phone is charging or the screen is on- not when the screen is off on battery power, like on Kitkat.
Mine downloaded last night while I was sleeping.
I noticed it says 5.0.1 0n the version.
I pretty much stay stock so we will see what gives in a day or two.
My wife's s5 still is on kit Kat ??
Anyhow Good Luck to all of you ,remember were android not apple
Mine has the two arrows but won't start downloading it for some reason??
Just turned on WIFI and automatically started downloading. Plugged in charger and lettting it go. Will return to comment when its done.
So my Note 4 updated last night, Spent the day in a zero coverage area, no wifi, no cellular. Phone was down to 12% battery after 12 hours. We will see what happens tomorrow.
That doesn't sound good
I usually get 24-36 hours before update
today I am down to 50% in about 14 hours of moderate use
I was in a major dead zone, like 70 feet underground all day. ZERO signal, it killed my Gear S too.
I had the download in a postponed mode. I deathly afraid to up date my week old phone. Seems there is a lot of issues after updating
I updated today. So far I haven't found any problems.
Sent from my iPad using Tapatalk HD
Just finished updating. Guess my Note 4 was set up to update automatically. I really wanted to wait a bit before updating to lollipop. Oh well, my fault. I should have checked my settings. I'll just have to see how it all plays out, I guess.
Posted via the Android Central App on my Samsung Galaxy Note 4
I think that logo only shows if you are actually on att network, I use att branded phones on my straight talk acount and my note 4 is the 910A when I put the wife's att Sim in my note 4 it shows att's logo BUT when I put my straight talk Sim in it always shows HOME.
I thinks it's to do with network and which APN you are using.
I'm also experiencing some more battery drain and I did clear cache and reboot a couple of times. I'm seeing my phone "awake" a lot.
Using G SAM battery monitor it doesn't allow me to drill down much on these wake locks. I turned off location history earlier today and still same results. Really dreading a restore. Restores are one great advantage that iOS has over android. I hate having to set everything back up again.
I'll give it a few days to settle down and hope it gets better.
This is something that really grinds my gears with Android and why I disable the OTA updater to take back control of my device so this doesn't happen. IMO this is one area Android really needs to mature in and provide a native way to control OS updates (ex. like Microsoft does with Windows where you have the option to set OS software updates to: Automatic, Notify only, or Disable). As it is now without killing the updater, you're at the mercy of Google, the OEM, or your carrier. Your device may get updated in the middle of the night or worse; a time when you need to use it whether you wanted it to or not. Either way it results in the user spending an inordinate amount of unplanned time troubleshooting and trying to fix a problem the update introduced to what was otherwise previously a problem free working device. :(
I completely agree with you. Going back to my original Android phone about 5 years ago I don't ever remember the phone updating the OS by itself. I always had to check for updates and if available select download. I wasn't going to immediately upgrade to Lollipop but I had no choice as the download was almost 2 hours into it before I realized it was downloading Lollipop. So whether I want it or not I've got Lollipop.
One thing I noticed other posters commenting about was the Play Store update. My phone did update the Play Store app after it rebooted from the Lollipop install. Only thing I found a few minutes into using Lollipop is my contacts which are in a custom view were not the same custom view I had in Kit Kat.
This update should not have happened with the user specifically wanting it to but fortunately I didn't need to use my phone and after the better part of 2 hours downloading I'm not going to cancel it. During the download I think the phone was still completely functional, it was only during the install & app updating which took probably 15 minutes at most that the phone wasn't functional. Reason I didn't want Lollipop immediately is I wanted to follow this thread to see what issues were reported first.
ihtasham
