anon(10562251)
Banned
- Dec 16, 2018
- 75
- 0
- 0
Sounds like they have blacklisted your device.Again, this option ain't available on AT&T anywhere on settings even though it used to be on my s8+.
Nope, already called them and asked for my imei status. If it was blacklisted it wouldn't even connect.Sounds like they have blacklisted your device.
Sorry... I meant blacklisted in the sense of blocked enhanced services from carrier ie. so-called "greymarket" and/or non-carrier device.Nope, already called them and asked for my imei status. If it was blacklisted it wouldn't even connect.
Well, for what it's worth, I do have wifi calling and everything else and my calls are volte enabled. What we're all debating here is the fact that there used to be a toggle for this function in our previous phones and now there isn't.Sorry... I meant blacklisted in the sense of blocked enhanced services from carrier ie. so-called "greymarket" and/or non-carrier device.
OK...the title of the thread is "no VOLTE" so perhaps I missed something. On my S10+ I do have a specific toggle to turn VoLTE on and off, so if that option is missing for some I would suspect it's because the carrier has blocked the service.Well, for what it's worth, I do have wifi calling and everything else and my calls are volte enabled. What we're all debating here is the fact that there used to be a toggle for this function in our previous phones and now there isn't.
What carrier your on ?OK...the title of the thread is "no VOLTE" so perhaps I missed something. On my S10+ I do have a specific toggle to turn VoLTE on and off, so if that option is missing for some I would suspect it's because the carrier has blocked the service.
Its an additional option in Network settings. Pixel has it. So does iPhone. If VoLTE is being enabled automatically somehow and this setting doesn't exist, then IMS should show up as registered under Settings/About Phone/IMS status. Otherwise you're not getting VoLTE.Probably why you see the toggle.
Different phones , but my 1+6 has the toggle which is global unlocked with my tmobile sim or Att sim, iPhone x on tmobile dont have a toggle, my note 9 on att or tmobile dont have a toggle, my pixel 2xl and 3xl on att or tmobile do, my s10+ on tmobile dontIts an additional option in Network settings. Pixel has it. So does iPhone. If VoLTE is being enabled automatically somehow and this setting doesn't exist, then IMS should show up as registered under Settings/About Phone/IMS status. Otherwise you're not getting VoLTE.
To avoid any confusion, I should probably add HD calling and VoLTE are not the same thing...
Is IMS registered on all those phones?Different phones , but my 1+6 has the toggle which is global unlocked with my tmobile sim or Att sim, iPhone x on tmobile dont have a toggle, my note 9 on att or tmobile dont have a toggle, my pixel 2xl and 3xl on att or tmobile do, my s10+ on tmobile dont
It is also possible to have VoLTE service enabled on your account, but the carrier does not support your device for it and therefore no VoLTE.Nope. The service itself isn't blocked.
The carrier has chosen not to show the toggle.
T-Mobile, same thing.
If your phone is not branded AT&T or T-Mobile, then you're in a different situation.
you need to have VoLTE to have HD calling.
The problem is confusing HD voice with VoLTE. If you guys want to believe they are the same thing, go ahead. Just know that if there is/was a toggle in the menu for HD voice on AT&T (or whatever carrier), that it has absolutely nothing to do with VoLTE. Never did.Of course, that's not what we're talking about here at all. Never was.
