AT&T Update to NK3 hitting now.
I downloaded this and now my messenger is syncing with Att cloud.... horrible... overtime I open the messenger it downloads ALL the text I have sent from July 2013... I delete and when I re-open it re-downloads them.... BEWARE
Go into your att account and remove the service.
After updating I am no longer receiving any notifications from hangouts users. SMS works fine, emails, apps, etc are notifying but hangouts users just won't work. I turned the setting off and on and restarted my phone 3 times and nothing is fixing it.
Perhaps try uninstalling then reinstall. Maybe that will work.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Fenix isn;t giving me notifications anymore... Not sure if updated caused it or not. I uninstalled and reinstalled and nada.
Someone told me after an updated I should restore my phone as new, do you all recommend that?
Battery was already great but update made out even Better!
I can't see any difference after the update including battery life which was excellent to begin with.
I see a difference in the quickness of recent apps and my battery usage is Italy about 4% an hour. Today it was less than 2%
Rather than uninstall/reinstall my suggestion would be to go to the Applications Manager and clear the data and cache in the app. Then restart the phone and see if it works then.
Kevin
Is anyone else having a problem with "Bluetooth sharing stopping" after this update? Ever since updating, my Gear Neo watch and phone have been throwing a fit everytime a second paired Bluetooth device is near (like in car audio or Bose sound link)!
Did anyone noticed on the AT&T update they install Evernote and you can't deleted it?
I just hide the apps, but why force this on people phone and you can't deleted it.
I think the Amazon app was part of the update too as I don't recall it being installed prior to the update. Some of the apps that are pre-installed are getting really ridiculous like Uber & Famigo. I wonder how many N4 users use their Uber app. Obviously these companies are paying the carriers to pre-install their apps.
I haven't noticed a difference in performance and I'm assuming that the HD voice is enabled already because I don't see a setting for it.
HD voice is automatic. If you have it, and the other person has it, and you are both on the same carrier (this is changing eventually) and you are both in an area with hd voice coverage, then it just works. Semi limited coverage for it right now, only a few compatible devices also. Google it for a list.
Jeez. You have to be on the same carrier.
I'm having this EXACT same problem with my fitbit. The Bluetooth disconnects in my car when I'm having a conversation with someone and when my Fitbit Bluetooth sync is on.
Before the update I was getting 6 to 6 1/2 hrs SOT. After I dropped to 4-4 1/2. After clearing cache partition I went anywhere from 4 1/2- 5 1/2 hours. I need to factory reset to see if the battery either returns to normal or gets better.
djdjjkzzz
