Atrix Screenshots: Share Them Here!
My current main homescreen
Beautiful Widgets Superclock on top with HD weather, clock has honeyclock_solid skin
Circle Battery widget and Simple calendar
WiFi Manager
Widgetsoid 2.x for screen lock and volume toggle
Also, here are some of my other screens. I took these before I put my new dock on
Minimalistic text clock on top
SimiFolder Widget on the left
Astrid Tasks lists
Beautiful Widgets Weather
Pure Calendar Widget
All custom docks
I'm glad my home screen setup is continuing to be popular.
First setup from way back on Feb24 when i first got the phone
how it looks now.
left screens contain desktop visualizer widgets with transparent icons. Click on them and you get folder pop ups with most used apps and games.
I would love to get a hold of these transparent icons. Any help would be appreciated.
New setup I have running. Went from 7 windows to 5.
I'm using circle launcher going horizontal with barely visible touch Icons to keep a more minimal look. The smaller pics at the bottom show what icons I have attached to each of the circle launcher buttons.
Had to Black out names on FB and Messaging widgets. ; )
Finished setup.
Home:
ADW Launcher Ex, no dock
Icons White from XDA
Circle battery widget
Make your own clock pro
Beautiful Widget Weather
Minimalistic Text Weather Info
Player Pro Widget
WidgetSoid
Audio Manager Pro
World Clock
Finished setup.
Home:
Player Pro Widget
WidgetSoid
Audio Manager Pro
World Clock
Love your set up! And am definitely about to check out World Clock and Audio manager pro. Thanks for sharing!
Here is my phone. Using gingerblur on 1.83 w/ blue steel theme. Screenshots are taken by ScreenshotER. Works awesome.
Screenshot 4, what is the app that allows the extra sliders? Also, the background, thanks ahead of time...
Is it lockscreen widget? If so, any negative effects, lag, etc? Love the idea of a camera slider, might have to steal that from you.
I can't say for sure but my guess is he's using WidgetLocker, current version sometimes doesn't work right with the latest 4.1.8.3 update but hopefully they will update the app soon and then it should go back to working as normal.
Yes it is widget locker, no lag or anything. Its actually pretty nice. Kind of has a screwy affect with the dot pattern if you have the enabled. I dont bother w/ the finger print scanner or the dot patterns so it works fine for me. It enables you to unlock using the volume buttons as well which is nice because my lock button is starting to deteriorate. The background is from this forum.
The wallpapers were found in this thread:
http://forum.androidcentral.com/wallpapers-ringtones-themes/49497-android-logo-wallpapers-5.html
witnessloc23
