ATT Note 3 update 4.4.4?????
Since my update I am experiencing no incoming or outgoing phone calls at times and messages about emergency calls only. I would post a link to the full thread but apparently you must have 10 posts in order to post a link. (guys I get the reason for doing that but you should write an exception for links on the site!). Basically my network is dropping in and out. My wife has the same Note 3 and is on version 4.4.2 and her phone is fine. I have changed the sim and restored back to factory but I still am seeing periodic issues. I will dial voicemail or someone else it looks like it is trying to dial but no ringing and it just kills it after a bit.
I updated last night, didn't really look around for new stuff. This morning I went on my daily run, the GPS didn't track well at all. Not sure if it needs to be recalibrated or not.
I've tried samsung kies and it say no update tried in phone update and says I'm up to date...still on 4.4.2 I wonder if the Sim card I had in my iPhone has anything to do with it because I can make calls no problem but I have 4 lines and used that one in iphone other than that I don't why no notification
SAMSUNG NOTE 3
My phone is doing fine. I had another thread about svoice being messed up but I got that taken care of. I have had issues with the GPS tracking as well. It never drops or anything but will locate me then stay frozen for a minute or two then locate me and it just keeps cycling like that.
I'm also having issues with the GPS after the update to 4.4.4, it has told me several times that it is not able to connect to a satellite, where before I would immediately get a connection and it would locate me on a may within seconds and hold tracking just fine for navigation. If anyone is able to find something to fix the GPS tracking let us know.
Updated 2 days ago. Major issues, I have no access to mobile data, group txt, sending/receiving images/downloads and more.
I've done a factory reset and even visited AT&T (which was pointless). Going to try the Samsung store tomorrow. According to the people at att there are many people having issues.
If you didn't Odin back to stock then the upgrade will fail. Removing root is not enough, you need to go back to a fresh stock install.
Scrolling - I have noticed that scrolling with a finger flip has gotten less "fluid" since the update to 4.4.4.
Seems to hesitate or even refuses some times. To be fair this may be a separate issue but I am not aware of having changed anything.
Me too. I wonder if there is a setting ... I haven't checked to see if Animation is back on.
I updated my AT&T Note 3 on 11/22 and I have had no mobile data connectivity since. I spent an hour talking to an AT&T rep today about it and he finally said he was clueless. He advised me to take it to Best Buy and let them work on it. He said there is nothing he can do.
Anybody else lose mobile data after the update?
Check your APN network settings. I saw after the update there was a new ATT APN on my phone that was selected by default. ..I use Cricket, so I had to switch it back to my Cricket APN
Try going into settings, then more networks make sure mobile data is checked. .if it is then same menu check and see access point is lit green , sometimes software updates turn them off...
NOTE 3
Hmm, just tried to access the phone via USB cable from my Win7 laptop.
The phone _is_ charging thru the USB cable so I've got connectivity. But the Laptop doesn't see the phone as a USB device.
On the Note3 I checked home: menu: connections: USB tethering and that's greyed out.
I tried a different USB connector on the Laptop and got the same result.
I telling you. Save the agrevation and wipe you device in the settings and then do the ota update...my not 3 is insanely fast now...
guys, is anyone noticing s-view crashing after this update? it gives message saying com.sec.android.sviewcover has stopped.
I haven't had the issues. My phone is like a brand new device out of the box. Very fast and stable. Call quality is awesome. Download and data speeds are very fast.
maryhurst515
