ATT Note 3 update 4.4.4?????
Yes. I just did the update last night and now I am getting the android.sviewcover has stopped. I am using a Seidio S-View cover for my GNote 3 and after the update it is not working properly. I have no idea how to correct this problem. I am not sure if I have any other problems related to the 4.4.4 update.
I telling you. Save the agrevation and wipe you device in the settings and then do the ota update...my not 3 is insanely fast now...
Morpheus, can you pls share the procedure. I am considering the wipe. Did you back up to Kies, then wipe, etc.
thx
Yes back up with kies. Then on your phone go to Settings|General|backup and reset. Once there, the bottom item should be factory data reset. Hit that and follow screen prompts. Keep it plugged in for all this. Once that is completed, and your device has rebooted, look for the ota update like you normally do. It should download fast and work with no issues. After the up paste is complete, you can begin restoring your device by using kies. My apps didn't load on their own, which was fine for me. I just installed the ones that I use regularly orapps that I needed like banking apps. Hope this helps!
yep horrible gps. honestly maps isnt using the gps at all. It was working awesome prior to the update . help !:(
Guess I am lucky. I am not experiencing any problems after the update. It's been a few days and everything is just fine.
Posted via Android Central App on my Samsung Galaxy Note 3
Re: ATT Galaxy S4 update 4.4.4?????
I currently have firmware version 4.4.2. If I update to 4.4.4, will my saved photos and apps be saved?
Just flashed Stock NC2, successful....still get the "interrupted/Not Available" try again in 24 hours. May just not have made it down here in Cajun Land yet I guess!
Decided to go ahead and do the "Reset to Factory Default" after getting the "interrupted/Not Available" notice...so after reset, checked for update again, and bam, downloaded and installed no issues.
So, once you reflash NC2, do a factory reset...should work then. Here's the link to Flash NC2: How to Unbrick AT&T Galaxy Note 3 SM-N900A
My gps is acting strange after the update. Always looking for my location.
My emoticons are working 😉 my emails loads very slow...
There was really no change with 4.4.4 except adding Kids Mode. The battery might have improved a little, but that was it.
Then how to i update it? :(
Is there a way of manually updating it?
You can't get it OTA or through Kies. According to the users here with ATT Note 3's, it is not available through Kies, and if you don't have your phone registered on the ATT network (which you wouldn't in Bangladesh), you cannot get it OTA.
You can go over to the XDA Developers forum and see if someone uploaded the firmware there and flash it with Odin. This is all assuming you have an ATT Note 3 model to begin with.
Well, I was wrong. I did have issues with my messaging, but thanks to Kelly Kearns all is now as it should be.
Kies and my phone say I have current software I called att and they told me that they might of had pulled the update because people were loosing contacts :c
Bitterbuthappy
