- Nov 23, 2016
- 1
- 0
- 0
Hi everyone, I've got an issue with my new S7 Edge. The audio settings randomly change on their own. Let's say I mute the sound, a few seconds/or minutes later the setting will have changed for the regular mode, with the ringtone. It doesn't seem to follow any pattern, it doesn't occur after I did something specific.
And that is very problematic. During the night I turn on the plane mode to avoid being woken up by a text message, and at work I have to use the do not disturb mode. The mute mode just won't stick, and I have no idea how to fix it.
The phone is rooted, and I tried to check the applications' permissions to see which ones had access to the audio settings, but I didn't find anything conclusive.
I hope you'll be able to help me figure it out.
Thanks
Thanks
