Autocorrect change?
Status
Not open for further replies.
Turn off "Auto Check Spelling" then on the keyboard itself turn "Auto Replace" on. Should work just fine or at least better.
Thanks for this, but I don't feel I'm noticing much difference. And actually this brings back the issue that I can't use Googles speech to text. I think Swiftkey has won my loyalty, though I REALLY wish they had a shortcut menu (like OMW = on my way spelled out).
Im the one that originally had the issues. Still there, autocorrect is just crap. Been using swiftkey and it worls great but I still like the way the Samsung one looks. I've been meaning to do a factory reset but i just don't have the time to set everything up from scratch again.
tried to do a factory reset and even resetting just the keyboard to factory, it did nothing. I even picked up the replacement today for the recall and it is still doing the same exact thing. I don't recommend having to re-setup the phone as it will probably not work for you as well...
This didn't fix it for me but as The_Dude said, it is "better". However I'm still stuck with being forced to use Samsung's voice to text when using their keyboard and I don't like it...so sticking with SwiftKey so I can use Google voice to text.
Im having thw same issue with my note 7 as well.. it will make the suggestion but not initiate the change when i hit the space bar. Many times it does NOT make the suggestion either. Maybe this is a system wide Marshmellow I issue. When i had my note 5 this was a non issue. Now its a major pain in the butt!
I installed SwiftKey and it works way better now. Actually works as it's supposed to. I prefer the samasung keyboard look over SwiftKey but at least this works! Maybe the issue is the Samsung keyboard... Who knows
Status
maryhurst515
