[Automated] Wug's Nexus Root Toolkit v1.6.2 (Updated 12/29/12)
Re: [Automated] Wug's Galaxy Nexus Root Toolkit v1.3 (Updated 1/2
Need a bit of help.
Was trying to get back to stock and now my phone will not get past the battery logo.
I have tried to get it to go into the bootloader but its just stuck on the battery, computer will not recognize the phone so i cannot abd any commands. Any ideas?
CWM was on the phone via Rommanger
If you can't get into bootloader, you are going to want to try to get into download/ODIN mode (volume down and power button) and use ODIN to restore your device. Here are working links for the files you will need (CDMA... if you are GSM let me know and I will hunt it down if you can't find it):
VzW-SCHi515-FactoryODIN-ICL53F-4.0.2.7z
Odin3_v1.3.exe
You will need a program like 7zip to unzip the ODIN package.
Here is a thread on using ODIN: [ODIN][ROM][ICL53F][FACTORY] Full Factory ODIN restore 4.0.2 with radios - unrooted - RootzWiki
If your drivers are already configured with my toolkit, then at least that's taken care of...
If you can get ODIN to see your phone, then you will be all set. It's a great tool if you really are out of options. Let me know how it goes or if you have any other questions.
{{ WugFresh }}
I followed the instructions to the letter and in the driver stage my device isn't showing up. not sure if it matters but the only computer I have working is using XP.
After it asks me if my fastbooter is there and i press 1 , while rooting, my computer restarts and it messes up the whole process. Any idea of what's wrong?:(
That doesn't make any sense. There is no code in my program that forces a restart. Maybe it was windows update? Have you tried more than once...?
{{ WugFresh }}
Reactions: JanioPerez
{{ WugFresh }}
Yes i have tried multiple tries and i dont have any updates to install. its giving me a Fastboot Command Read Error -2147483647. i also tried multiple usb ports as you have suggested that on another forum. Before the error appears is says Fastboot Status Downloadin 005005000 or something like that.
BTW : thanks for replying so quickly. i appreciate it as i am a new rooter
{{ WugFresh }}
yes i have. its giving a fastboot command read error -21474836. i have tried multiple usb ports as well. my computer needs no updates. its windows xp.
Nice program and guide, really appreciate it. I seem to be a little stuck though.
I thought I installed the drivers correctly, I see "SAMSUNG Android ADB Interface" under Samsung Android phone in the device manager. When I go to the cmd and type in adb devices I get "'adb' is not a recognized as an internal or external command, operable program or batch file" I cannot get the device name with a string of numbers. Using windows xp
Use the list devices button in the program instead.
If you want to be able to call adb cmds globally from cmd line manually, then use the system variables button to update your systems path variable. You might also need to reboot once in order for it to fully set.
{{ WugFresh }}
Reactions: Bobaroo
Add me on gchat.. i am very confused by your error. Have you hash checked your download? Are you using the stock Samsung usb cord?
{{ WugFresh }}
{{ WugFresh }}
Thanks. I'll look into it. At work now so hopefully I have some time later tonight
I really appreciate the easy instructions! I unlocked and rooted my phone with ease... I then tried to flash a rom through rom manager and everything downloaded ota just fine. I installed codename android and things still seemed just fine but I've been stuck in the boot animation screen for 20 mins. The toolkit says its waiting on device so I basically cant do anything? Anyone have any advice on what my next step should be? (Ive already tried the battery pull)
Which version of Codename did you install? Can you copy and paste the link that you used so I can take a look at it?. Also don't use ROM Manager to download and flash ROMs. Only use it for booting into ClockworkMod recovery.. download ROMs from the developers website links.
You're next step if the phone won't start up is to flash your Nandroid Backup... hopefully you made one.
http://forums.androidcentral.com/ve...backup-restore-install-roms-galaxy-nexus.html
Thanks for your help! I think i figured it out
I used your awesome tool kit to unlock/root so that I could use Rom Mgr to flash 4.0.4. All went well, I am now running 4.0.4 but..... after flashing, I lost root. I have tried re-rooting with the tool kit. The batch seems to run fine but still no root. Not sure what to do except Flash Stock and start over from fresh. Do you have any other suggestions????
Thanks again.
As soon as I get everything working I will be happy to use your "Please Donate" link.
Thanks again.
You need to flash a modded su.zip for 4.0.4 - http://goo-inside.me/devs/WugFresh/Miscellaneous/su.zip
You could boot into clockwork and flash that. Or replace the su.zip that is currently in the package with that one and run through the root process again.
It resides here:
%HOMEDRIVE%\Wugs_GnexRootToolkit\data\su.zip
Version 1.4 of my program will include this.. which should be released by tommorow... but for now, the above solution will work.
{{ WugFresh }}
So once I have run the program will it automatically update me to 4.0.4? Or will I need to get that somewhere else? And if I do, how do I update to 4.0.4?
Could i also use this program to flash yakju so that my Canadian gnex gets OTA updates?
So a reboot of the phone seemed to get the drivers installed. It sees the adb device and lists a string of numbers/letters.
So I go to unlock, hit any key. I see my listed device attached so I hit 1. It than reboots in fastboot mode. At this point the program asks again do I see any fastboot device listed above...and this time I don't
edit: NVM, didn't have the fastboot drivers installed correctly, I fixed that. Phone is now unlocked!
gurusdex
