Battery barely charging
Jay Sacks
652
All of a sudden my battery is taking 5 hours to charge 10% (average). Shows 70% with 15 hours to full charge and I have been checking. Used multiple chargers and cables with same result.
Anyone think a reset might help?
Or is my looks brand new tablet dead?
Might be a faulty model. Those problems go as Battery problems. If it was old and used, i would say it was the battery myself but it might be the charging port too. If you are still in a warranty, just get it back for check-up.
But i would try Hard reset in it to see if it would work and if it does, skip the hassle of getting the warranty!
Seems holding down the power button and volume down at the same time does some type of reset. Did a Google search and this was recommended for resetting the charging cycle. Seems to have worked.
KidColoringPage
