Battery Died in the middle of a recovery in ClockworkMod. HELP HELP HELP!!!!!!!!!!!
BryanGonzalez
7
please, please help me, I was recovering my phone via clockworkmod, and the battery ran out in the process after a wipe. Now, when I plug in, it vibrates, the battery loads up, then dissapears. Is my phone bricked? What do I do? HELP!
When I plug in my phone it does the same thing and it's fine, it's supposed to do that. Did you try turning it on?
Well, you learned one thing. Don't go screwing with your phone if the battery is low.
Always plug it in when updating/changing the OS.
did you have your phone plugged in during the process?
The only solution I'm aware of is to find someone offering JTAG services - it should still be recoverable for them.
There was some guy that pointed out a video about how to recover from a hard-brick by putting an OS image on a 2nd partition of an SD card, and somehow the phone would boot to that and reload the firmware - you can search for that and give it a try.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
