Battery drain from calls
nogutsnoglory
72
3
I know there have been a number of threads about battery drain after installation of ICS. My question is this: does it seem right to have 8% battery drain from a lousy 10 minutes of phone calls? That translates into about 2 hours of talk time only on a full charge. That seems very low. Any thoughts?
Although the Screen shot says the battery was at 90%, a different more accurate app says it was 87%.
Then you should have nothing to worry about. On screen time uses up more battery than anything really (goes up when surfing the Web, especially
On 4g)
Sent from my DROID RAZR using Android Central Forums
from what i understand, it means only 8% of the total battery drain was taken up by the phone call. add that percentage to the rest in the list and you come up with 100%. now each app that takes up a percentage, contributed to the batter drain you've seen. make sense?
Reactions: B. Diddy
Filthybreeze
