battery draining during standby
david61983
227
I have the 2014 Moto X, and it drains tons of battery while on standby. I'll go to bed with it at 90% and wake up 8 hours later it will be 40%. Anyone know of a fix? I have the wife turned off and no apps running.
maduro78
190
Has to be a wakelock or something of the sorts. Download gsam battery monitor to see what's killing the battery. Post the results after a full battery cycle
Moto X 2014
itinj6
282
I know you meant "WIFI" but I couldn't help chuckling when I read your OP. Good luck with finding a solution!
Louis Manning
One thing i did was put the battery saver on. It basically disables a ton of background functionality but you should still get calls and texts. I made a shortcut just so I can toggle as needed when I know I won't need the phone for a while. This should work with any night mode you have setup as well. It's something to consider.
NickA
1,617
117
63
Does it just happen at night? If so, I would say bad cell reception where ever you put your phone (night stand?).
Also, and I always ask this question, why not just leave your phone plugged in and charging overnight? Unplug in the morning and start the day with 100% battery.
dxter
