Battery draining on s20 fe 5 g android 11
Liorid
108
Hello and marry Christmas
Yesterday i update my s20 fe 5g to android 11
I think my phone have a battery drain problem
After the update i did a wipe cache partition buy yet i thing there is a battery drain
With android 10 i had like between 6 and 7 hours of soc
Yesterday i had less then 4.5 hours
Someone have the same problem?
See how it is after a few more battery charge cycles. Sometimes it takes a day or so for things to settle out.
You sure it's Android 11 or the December security patch? Mine drains a bit quicker but lasts longer now around the 60% range. But I'm still on Android 10.
amaka
