i have seen some battery level drop on my moto z play on standby time recently.
for example, normal use - when i go to bed and the battery level is at 100%, after 8 hours of no use, it might drop 1 or 2 percentage points - which is normal.
now i have seen it drop maybe 10-15 percentage points after the same 8 hours of no use.
something that I just recently did was i upgraded two of my apps that i download (i paid to remove the ads).
the apps that i paid to upgrade were calculator plus and chomp sms.
is it possible that the paid apps would drain my battery faster than the free apps?
if so, i would go back to the free apps with ads which would not be good since i just paid for the upgrade to remove the ads.
