Battery life article here?
I like how Samsung has those features, google should take notes give little better detail on how and what is being put to sleep and battery bar graphs not just 24 hours
Sent from my Pixel 7 Pro using AC Forums mobile app
I do like those features on my s22u a lot. I think google is more of an add them yourself to their version of deep sleep.
It took me a minute to realize that the screen time is located in the digital well being section. I am hesitant to add an app to calculate battery that uses the battery lol.
Yeah used battery apps in past , my battery last a day i consider that good battery not going stress over it .
I took my 7 Pro off the charger at 0615 this morning. It is now 2147 and I have 43% left. I connected to Android Auto a couple times today, via a usb connection - but that was low charging.
My usage today was moderate.
As far as I'm concerned has anyone here had to do an emergency charge up BEFORE going to bed because your battery was below 5%? If not then what are you complaining about? If you already know that you will not make it two days on one charge, and you are going to put it on the charger overnight, then what difference does it make if the phone is at 10%, 20%, or whatever % when you go to bed? Did it not make it through a full day on one charge? If so, the please STOP WHINING!
Had my P7P about 4 days. I'm experiencing pretty good battery life. It's a bit better than my P6P, which for me was pretty good and on par with my Samsung S22 Plus.
Now that I solved my rogue app issue I'm getting pretty decent battery including standby as well
Sent from my Pixel 7 Pro using Tapatalk
Nothing to report here P7 Pro has good battery life...I do have a charger in my car and at home so charging it as needed.
Battery life on my pixel 7 is nothing short of excellent. Best battery life of any phone I can recall. I always plug in at bedtime and take it off when I wake up. After using it a lot yesterday I went to bed with 49% still left at 11:30pm. The charger brings it up slowly to 80% about an hour before my alarm, holds it there until my alarm goes off I see it at 100%. I don’t have an overly excessive amount of apps and I always set up as fresh for every new device. If I was having some of the poor battery performance issues mentioned I’d be looking at each app for to much battery draw. If finding nothing I’d factory reset and reinstall fresh not from a backup. One other thing I always do is factory reset a new phone before I install anything, perhaps a bit OCD but once found a homemade porn vid on a Nokia phone brand new out of the box. Who knows what quirks I could be eliminating by factory resetting a fresh out of the box phone.
For me, this is the best battery life I've ever experienced on an Android device. I've had every Note, except the first one - I include S22 Ultra in that Note lineup.
Not even a full day in for me and I'm pretty pleased with the battery. I know it will get better with the adaptive capabilities once it learns my patterns. My only concern is I've yet to hook up my Galaxy watch, and I'm afraid once I do that the battery will be drastically affected.
I have mine hooked to my Galaxy watch 5 and still get all day battery. Better than on my s22ultra.
Put a hard day's use on the phone today - plenty of browsing, media, photo & video capture, a fair chunk of GPS...
Took it off the charger (100%) at 8am, and here I am at 8pm after 7h23m of screen time and I still have 16% battery left. Would it last me from when I rise to when I go to bed on my heaviest-use days? Probably not, but it wouldn't miss by much - and I put in for a special exemption from the ACP (Association for Criticism of Pixels) to be allowed to charge it mid-day if needed, so my hopes are high.
P7 Pro has basically the same size battery (actually 3 mAh less) when compared to the P6 Pro, but it's definitely doing better on battery life!
I'm getting nothing like that. I'm burning through 20 percent in a couple of hours of taking the odd photo and browsing.
xinyingt2
