Battery life is amazing
Medium usage day on Sunday and still 44% left at 8 PM. S10+
How do you get only 1% on android system?
I don't know, I don't generally change any setting. All accounts auto sync, NFC, Bluetooth, WiFi everything always on, highest resolution setting, adaptive/auto brightness on, no apps disabled or anything. Only thing I haven't turned on is the always on display which I have set up tap once to show the display.
I got 9 hrs and 21 mins with 2% left on Thursday night... longest screen time with medium to heavy use I've ever received from any phone.
Mine been slow but getting there
First charge got 5 hours, 40 mins usage then 4 hours, 45 mins maybe takes time to get the most from it
Today so far OK as I've moved everything to dark mode with black background
Regular S10 unlocked and I am getting excellent battery life. I was very worried about that after seeing GSM Arena’s results but mine is far better than theirs and WAY better than my old S9 (but not as good as my Mi A2 lite).
I have the S10 Plus verizon SD855 and battery has been good, but to early to tell. Need a week at work and need to let it settle in a bit.
Yeah you can try that , I didn't have to.
FHD +
Hey bro, I wanted to report back. Since I put adaptive power saving mode back on and rebooted my phone, it hasn't kicked me into medium power saving mode or turned off my AOD since. So the reboot must have done the trick.
Thank you!
Thank you!
Good to hear , thanks for the feedback
Your welcome.
How are you getting such great battery life? I don't get even close to 2 days and the most SOT I have gotten was a little over 5
I really dont have a answer, I've been using the phone a lot to test it out, all settings pretty much stock except adaptive power saving..but I get this kind of battery on my note 9 also .
My battery life is not great on my S10+ and I noticed the Google app is using about 6% of my battey (it is the #2 user behind screen and aboce phone idle). I have it set to optimizing battery usage and put the app to sleep when not in use but it is still being used in the background for 9 hours and 30 minutes today. I don't think it is set up differently than I have had with my Note 9 or S8 but I never had it kill my battery like this.
As a prospective S10+ exynos purchaser it would be appreciated if people could post model & processor variant 😊
U guys getting great battery life are yours unlocked or through a carrier. My note 9 is 2weeks old and battery life sucks. I just want to throw it against a wall. My 2yr old s8+ was almost as good as my new note 9. I know the s10 is newer tech then the note 9 but this is really upsetting.
Why what battery life you getting?
DannaOgle83
