Battery life issue
<<c. Keep WIFI on during Sleep - Set as ALWAYS if you regularly use
WIFI. OK to keep WIFI on if you regularly use it.>>
I turned this off and I can see a notable difference in battery life. It definitely lessens battery drain when the phone is sleeping. It's better to use an app like Smart WiFi Toggler that automatically turns on/off your WiFi based on connections you always use like home/work. You could use Llama or Tasker to do the same but this app is specifically for wifi only.
i suffer no hardships doing this -
Battery Tips for Android
1. Toggle off High Accuracy GPS Mode, Bluetooth, NFC,
Hotspot/Tethering. Toggle on only as needed. (Set GPS Mode to "Battery
Saving" Mode).
2. Display Brightness - Turn off Auto Brightness and Reduce Setting
Bar to Minimum Acceptable to you.
3. Sign out of any unused Google Services like G+, Google Now, Hangouts, etc.
4. Disable Location Reporting and Location History.
5. Beware of constantly syncing in background Apps and Bloatware like
Facebook, Twitter, Weather Channel, Games, Google News/Weather,
Non-Push Email, etc. Set Sync interval for every 1 hour or more and
change settings to stop the syncing of data you don't need. Delete
their Apps and use their Web Page if acceptable.
6. Turn Off Hot Word "Hotword Detection" Always Listening Mode in
Google Search if you don't use it.
7. Turn Off Auto Camera/Photo Upload or at least set it for Upload on WIFI Only.
8. Turn Off Vibrate on Touch for Display, Keyboard, etc.
9. Turn Off Touch Sounds and Unlock Sounds.
10. Turn Off Ambient Display/Active Display Notifications if you don't need it.
11. Don't use a Live Wallpaper. Use a dark wallpaper if possible.
12. Set Display Sleep Setting to 2 Minutes or Less.
13. WIFI Settings - Advanced -
a. Network Notification - Set as OFF.
b. Scanning Always Available - Set as OFF.
14. Turn Off Always Vibrate in Gmail/Email.
15. Be careful of using too many Live Widgets and what/how often they sync.
16. Set MS Exchange Sync at 30 Days or Less if you use it.
17. Do NOT use a Task Killer App or Battery Saver App.
18. Uninstall ALL Apps that you never use. If you haven't used an
App in one month, uninstall it.
19. Reboot your phone at least once a month.
20. Wipe Cache Partition at least once a quarter or after every OS Update.
21. Consider a Factory Data Reset with a manual re-sync, manual
reinstall of all data and Apps after every major OS Letter Update.
Make sure that all of your data is first backed up to Google and
Dropbox, etc.
5-20-15
So much fun, now I see why some people say - iPhone is boring..
I returned mine went to dinner at 530 pm then a movie got home at about 1030 and it was almost dead. Im back to my 6 plus. Really liked the phone but it was useless with the battery life. Still have an s5 too
Exactly right neiljay 6. You can't compare the IPhone 6S with the S6. But if you look at the specs on Verizon's website and compare the IPhone 6 with the Galaxy S6, they list the IPhone 6 as getting 10.5 hours of standby time and 14 hours of usage. The S6 is listed as getting 13 hours of standby and 20 hours of usage. It's just a matter of operating systems; Android needs to improve its Lollipop 5.0 (and/or 5.1) to remove unwanted battery drain. Apple also approves all of the apps that go on their phones; Samsung does not. Apple also doesn't have Google to contend with. I think all of these problems with battery power have to do with the fact that people can install ANY app they want on their Android phone, and they don;t have a clue as to what these apps are doing as far as using GPS location services, autosyncing, etc. Add to that Google services, which also use extra battery power unless they are configured properly.
I haven't used my phone much since I bought it a couple of days ago, just to see what kind of battery life I'm getting. My usage (since I charged it yesterday) so far is 1 day, 5h and 54 min. I have 41% battery remaining and 20 hours left! That pretty much gives me a total of 2 days and 1 hour of total battery time!
Even if I got considerably less than that, I would never get an IPhone. Never!
Actually iPhone's have the same radios in all their phones worldwide . The problem is software. iPhones have only iOS to deal with. There's no "carrier" bloatware to deal with. An iPhone sold in the U.S. is the same phone sold in Saudi Arabia. All the internal radios are the same(Model A1522). TD-SCDMA is used for China Mobile and Sprint(USA specifically(Model A1524)). Thats the only difference. iPhone 6+ Model numbers used
yettispagetti23
