Battery Life
I haven't disabled any apps (location and GPS is off though), but I am also not making a lot of calls or watching videos, (I mainly text and use wikipedia, reddit) and this is a normal battery cycle for me: http://i.imgur.com/YLW4Gaf.png
My record is 86 hours.
This may be a dumb question, but how did you go about disabling the applications? I've gone into most of these bloatware applications and disabled notifications and things like that, but is there something else I can do to disable them? I still see the amazon app and Life Square and a number of other applications still running even with notifications and everything turned off.
Here's what I found after I started reading this thread: support.verizonwireless.com/support/devices/knowledge_base.html/87306
I don't know why but I am getting a lot of my battery being used by android system and I disabled a bunch of things any clue?View attachment 88612View attachment 88613
Sent from my VS980 4G using AC Forums mobile app
I've only had the phone for 2 days and am getting awesome battery life so far. Right now I'm on 47% battery after 15 hours and 45 minutes of use and 2 hours and 12 minutes of screen on time. I'm very happy with this but I a
So am getting more percentage used by Android system. Glad to see I'm not the only one. Not too worried about it if the battery life keeps this way though.
Sent from my Nexus 7 using AC Forums mobile app
do you have facebook app installed? (or any other app that polls for data? Twitter/instagram/etc.?)
hedi-dev
